With video consumption at an all-time high, creatives need a better way to compile feedback. Frame-accurate commenting helps simplify the process of giving and receiving feedback on video files. Tag your collaborators to request feedback. Then, all they have to do is make a comment at a specific frame on a video timeline and you’ll be able to jump to the exact frame they’re referring to. Comments will appear alongside the media file in Dropbox for quick reference. The team can also add frame accurate comments to any screen recordings you create with Dropbox Capture.
Use frame-accurate commenting on commonly used file types files like QuickTime, MP3, WAV, and MXF. Now you don’t have to sift through emails for feedback. With all your notes in one place, you can execute those edits and move on to the next one.
